Two AD410 Doorbells + Max Smart Home Cameras
EddieColeslawski
Post by EddieColeslawski »
Hello,
I have 2 questions regarding Smart Home:
    • Is there any issue with using 2 AD410 doorbells in the same house (1 for front and back door), and can they sync to the same chime?
    • Is there any limit to the number of cameras that could be integrated to the Smart Home cloud? The KB article found here: https://support.amcrest.com/hc/en-us/ar ... -Explained isn't really clear on the quantity of cameras allowed, only the archival time.
      Thanks for your help!
    Re: Two AD410 Doorbells + Max Smart Home Cameras
    Well I do have 2 older AD110 on a 40 va transformer 1 indoor chime and 2 chime kits so because of use location i removed them to make a fast video of it. You can view action https://youtu.be/QeNkZRqhxJ4 at that YouTube location my guess is if the AD110 could do it then the 410 should as well. Sadly don't own any to confirm
    EddieColeslawski
    Thanks for taking the time to do that, Revo2Maxx. I'm going to go ahead with ordering the bells.
