ASH26 light does whatever it wants
Re: ASH26 light does whatever it wants
@nixhome2020 Sorry to hear that.
There can be many different reasons that a LED will flicker. On the ASH26 that is going to be even more difficult to pin down as it is not just an easy on off type of system like it would be wtih a normal homes motion light..
So when you turn on the LED Light if you can cover the flashing side to help cut down on being blinded can you tell if all the LEDS are coming on? If they are not (Might be hard to tell on some types of LED chips)
Or when you turn it on is there a Clicking sound that can be heard?
That is the 2 off the top of my head of an issue that could be why a LED outdoor light is flashing.
intarray
Post by intarray »
Does anyone have an old ASH26 Eng_N_V2.680.00AC00A.0.R.20200708 firmware of any kind?
Personally I would reach out to Amcrest and see if they can setup a transfer of that file for you. It can be risky getting FW from others.. If you were to do a ticket and ask about the FW they would be the best resource for the file.
